주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T460s Wi-Fi Card Replacement
필요한 것
  1. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Wi-Fi Card Replacement: 3 단계, 이미지 1/1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Wi-Fi Card Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: 4 단계, 이미지 3/3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 1/3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 2/3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 3/3
    • Disconnect the gray and black cables from the Wi-Fi card.
    • Remove the 3mm Phillips #1 screw on the chip.
    • Remove the Wi-Fi card from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
kewei xia
회원 가입일: 10/01/19
457 평판
안내서 2개 작성하였습니다
댓글 2개
which replacement modules would you recommend? I am looking for alternatives to the 8260 that seems to be flawed.
albert einstein - 답글
I have now replaced my Wifi-Card and just wanted to point that you instructions diverge from the official ones suggested by Lenovo. This manual simply recommends to deactivate the internal batteries through a bios option - which seems easier than the instructions laid out here.
still, cheers for your guide.
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 44
전체 시간: 3,105
