주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T470 SSD Replacement
필요한 것
  1. Lenovo ThinkPad T470 SSD Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T470 SSD Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T470 SSD Replacement, External Battery: 1 단계, 이미지 3/3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 SSD Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T470 SSD Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T470 SSD Replacement: 2 단계, 이미지 3/3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 SSD Replacement, Bottom Cover: 3 단계, 이미지 1/2 Lenovo ThinkPad T470 SSD Replacement, Bottom Cover: 3 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 SSD Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T470 SSD Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T470 SSD Replacement: 4 단계, 이미지 3/3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 SSD Replacement: 5 단계, 이미지 1/1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 SSD Replacement, SSD Assembly: 6 단계, 이미지 1/2 Lenovo ThinkPad T470 SSD Replacement, SSD Assembly: 6 단계, 이미지 2/2
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  7. Lenovo ThinkPad T470 SSD Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad T470 SSD Replacement: 7 단계, 이미지 2/2
    • Use the flat end of a spudger to separate the connector from its socket.
  8. Lenovo ThinkPad T470 SSD Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T470 SSD Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T470 SSD Replacement: 8 단계, 이미지 3/3
    • Grab the tab on the left side of the SSD assembly, and pull up to remove it from the laptop.
  9. Lenovo ThinkPad T470 SSD Replacement, SSD: 9 단계, 이미지 1/3 Lenovo ThinkPad T470 SSD Replacement, SSD: 9 단계, 이미지 2/3 Lenovo ThinkPad T470 SSD Replacement, SSD: 9 단계, 이미지 3/3
    • Use your fingers to detach the plastic bracket from the SSD assembly.
  10. Lenovo ThinkPad T470 SSD Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad T470 SSD Replacement: 10 단계, 이미지 2/2
    • Flip the SSD assembly over so that the green connector board is visible.
  11. Lenovo ThinkPad T470 SSD Replacement: 11 단계, 이미지 1/2 Lenovo ThinkPad T470 SSD Replacement: 11 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the metal bracket.
  12. Lenovo ThinkPad T470 SSD Replacement: 12 단계, 이미지 1/3 Lenovo ThinkPad T470 SSD Replacement: 12 단계, 이미지 2/3 Lenovo ThinkPad T470 SSD Replacement: 12 단계, 이미지 3/3
    • Use your hands to lift the metal bracket up and away from the SSD assembly.
    • There may be some adhesive attaching the metal bracket to the SSD.
  13. Lenovo ThinkPad T470 SSD Replacement: 13 단계, 이미지 1/1
    • Remove the single 4 mm screw using a Phillips #1 screwdriver.
  14. Lenovo ThinkPad T470 SSD Replacement: 14 단계, 이미지 1/2 Lenovo ThinkPad T470 SSD Replacement: 14 단계, 이미지 2/2
    • Use the flat end of a spudger to pry the SSD up slightly and pull it out of the slot with your other hand.
  15. Lenovo ThinkPad T470 SSD Replacement: 15 단계, 이미지 1/2 Lenovo ThinkPad T470 SSD Replacement: 15 단계, 이미지 2/2
    • Remove the two 4 mm screws from the SSD connector board using a Phillips #1 screwdriver.
  16. Lenovo ThinkPad T470 SSD Replacement: 16 단계, 이미지 1/2 Lenovo ThinkPad T470 SSD Replacement: 16 단계, 이미지 2/2
    • Use your hand to remove the SSD connector board from the metal enclosure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kristen Gismondi
회원 가입일: 11/12/14
85,251 평판
안내서 215개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 20
7일 전: 135
30일 전: 500
전체 시간: 17,195
