주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T470 Wi-Fi Card Replacement
필요한 것
  1. Lenovo ThinkPad T470 Wi-Fi Card Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T470 Wi-Fi Card Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T470 Wi-Fi Card Replacement, External Battery: 1 단계, 이미지 3/3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Wi-Fi Card Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T470 Wi-Fi Card Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T470 Wi-Fi Card Replacement: 2 단계, 이미지 3/3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Wi-Fi Card Replacement, Bottom Cover: 3 단계, 이미지 1/2 Lenovo ThinkPad T470 Wi-Fi Card Replacement, Bottom Cover: 3 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Wi-Fi Card Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T470 Wi-Fi Card Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T470 Wi-Fi Card Replacement: 4 단계, 이미지 3/3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Wi-Fi Card Replacement: 5 단계, 이미지 1/1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 Wi-Fi Card Replacement, Wi-Fi Card: 6 단계, 이미지 1/2 Lenovo ThinkPad T470 Wi-Fi Card Replacement, Wi-Fi Card: 6 단계, 이미지 2/2
    • Use a finger to press the black flap covering the Wi-Fi card down.
  7. Lenovo ThinkPad T470 Wi-Fi Card Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad T470 Wi-Fi Card Replacement: 7 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the two coaxial wires from the Wi-Fi card.
    • When reassembling, reattach the gray wire on the left and the black wire on the right.
  8. Lenovo ThinkPad T470 Wi-Fi Card Replacement: 8 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the Wi-Fi card.
  9. Lenovo ThinkPad T470 Wi-Fi Card Replacement: 9 단계, 이미지 1/2 Lenovo ThinkPad T470 Wi-Fi Card Replacement: 9 단계, 이미지 2/2
    • Use your fingers to lift the Wi-Fi card up and out of its slot.
    • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 6-9 to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kristen Gismondi
회원 가입일: 11/12/14
85,251 평판
안내서 215개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 84
전체 시간: 2,374
