소개
There are two batteries in the Lenovo ThinkPad T470S. We will show you how to replace both of them in this guide. The batteries need to be replaced if your computer isn’t holding a charge or only works when connected directly to power. This repair should be quick and easy as long as you have the batteries for replacement.
In Windows, battery 1 (00HW023) is the larger of the two and sits under the track pad. Battery 2 (01AV406) is the smaller one and sits by the hinge to the screen.
필요한 것
Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
Lift the bottom panel up and off the laptop.
Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
Peel back connecting supporting tape on each of the batteries.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
Is the rear battery, battery 1 or 2? It's my battery 2 that won't charge any more. But maybe I should just change them both. Do you sell both of them or just the one?
