주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480 Back Cover Replacement
필요한 것
  1. Lenovo ThinkPad T480 Back Cover Replacement, External Battery: 1 단계, 이미지 1/2 Lenovo ThinkPad T480 Back Cover Replacement, External Battery: 1 단계, 이미지 2/2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Back Cover Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480 Back Cover Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480 Back Cover Replacement: 2 단계, 이미지 3/3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: 3 단계, 이미지 1/2 Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Back Cover Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T480 Back Cover Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T480 Back Cover Replacement: 4 단계, 이미지 3/3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sarah Westberg
회원 가입일: 03/11/19
23,288 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,303개 작성하였습니다
댓글 2개
Dont forget the 3 clips in the removable battery area. No one mentioned those and I ended up breaking a clip and cracking the bottom cover of my T480... :(
Neccros - 답글
Hey @neccros! Thanks for the feedback. I'm very sorry you cracked your bottom cover. I've updated the guide to incorporate your experience.
Sarah Westberg -
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 55
30일 전: 229
전체 시간: 6,426
