주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480 Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad T480 Hard Drive Replacement, External Battery: 1 단계, 이미지 1/2 Lenovo ThinkPad T480 Hard Drive Replacement, External Battery: 1 단계, 이미지 2/2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Hard Drive Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480 Hard Drive Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Hard Drive Replacement, Back Cover: 3 단계, 이미지 1/2 Lenovo ThinkPad T480 Hard Drive Replacement, Back Cover: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Hard Drive Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T480 Hard Drive Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T480 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Hard Drive Replacement, Internal Battery: 5 단계, 이미지 1/2 Lenovo ThinkPad T480 Hard Drive Replacement, Internal Battery: 5 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 Hard Drive Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T480 Hard Drive Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T480 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Hard Drive Replacement: 7 단계, 이미지 1/3 Lenovo ThinkPad T480 Hard Drive Replacement: 7 단계, 이미지 2/3 Lenovo ThinkPad T480 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
  8. Lenovo ThinkPad T480 Hard Drive Replacement, Hard Drive: 8 단계, 이미지 1/3 Lenovo ThinkPad T480 Hard Drive Replacement, Hard Drive: 8 단계, 이미지 2/3 Lenovo ThinkPad T480 Hard Drive Replacement, Hard Drive: 8 단계, 이미지 3/3
    • Using the black nylon spudger, lift the connector lock up.
    • Disconnect the storage cable from the motherboard.
  9. Lenovo ThinkPad T480 Hard Drive Replacement: 9 단계, 이미지 1/3 Lenovo ThinkPad T480 Hard Drive Replacement: 9 단계, 이미지 2/3 Lenovo ThinkPad T480 Hard Drive Replacement: 9 단계, 이미지 3/3
    • Lift the hard drive up with a tab if it has one or with your spudger.
    • Lift the drive assembly from the system.
  10. Lenovo ThinkPad T480 Hard Drive Replacement: 10 단계, 이미지 1/3 Lenovo ThinkPad T480 Hard Drive Replacement: 10 단계, 이미지 2/3 Lenovo ThinkPad T480 Hard Drive Replacement: 10 단계, 이미지 3/3
    • Pull the plastic drive bracket outward to remove it from the hard drive.
  11. Lenovo ThinkPad T480 Hard Drive Replacement: 11 단계, 이미지 1/2 Lenovo ThinkPad T480 Hard Drive Replacement: 11 단계, 이미지 2/2
    • Flip it over and remove the drive connector from the assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sarah Westberg
회원 가입일: 03/11/19
23,194 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,144개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 144
30일 전: 672
전체 시간: 18,942
