주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480 Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: 1 단계, 이미지 1/2 Lenovo ThinkPad T480 Keyboard Replacement, External Battery: 1 단계, 이미지 2/2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Keyboard Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480 Keyboard Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480 Keyboard Replacement: 2 단계, 이미지 3/3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
  4. Lenovo ThinkPad T480 Keyboard Replacement: 4 단계, 이미지 1/1
    • Open the laptop so the keyboard is facing you.
  5. Lenovo ThinkPad T480 Keyboard Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T480 Keyboard Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T480 Keyboard Replacement: 5 단계, 이미지 3/3
    • Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
    • The keyboard is connected to the board by two ribbon connectors.
    • Be careful not to rip the connectors when you flip the keyboard over.
  6. Lenovo ThinkPad T480 Keyboard Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T480 Keyboard Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T480 Keyboard Replacement: 6 단계, 이미지 3/3
    • Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
    • Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
  7. Lenovo ThinkPad T480 Keyboard Replacement: 7 단계, 이미지 1/3 Lenovo ThinkPad T480 Keyboard Replacement: 7 단계, 이미지 2/3 Lenovo ThinkPad T480 Keyboard Replacement: 7 단계, 이미지 3/3
    • Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
  8. Lenovo ThinkPad T480 Keyboard Replacement: 8 단계, 이미지 1/2 Lenovo ThinkPad T480 Keyboard Replacement: 8 단계, 이미지 2/2
    • Remove the keyboard from the laptop.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Sarah Westberg
회원 가입일: 03/11/19
23,194 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,136개 작성하였습니다
댓글 3개
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
EagleCreeks Assortment - 답글
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
Sarah Westberg -
댓글 쓰기
조회 통계:
24 시간 전: 20
7일 전: 119
30일 전: 505
전체 시간: 11,783
