소개
If the keyboard becomes dirty, it loses keys, or it becomes non-functional, you might need to replace the keyboard of your Lenovo ThinkPad T480.
The keyboard is an integral component of your Lenovo ThinkPad T480. It is one of the main input devices of your laptop, allowing the user to enter data in the form of characters like numbers and letters into the computer.
This repair is an easy process. Just be sure to disable the internal battery, remove the external battery and unplug the device prior to beginning your fix. Also be careful when you remove the keyboard because it is connected to two cables on the underside that need to be detached.
필요한 것
Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
Thank you so much!
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
