소개
If you need to replace the LCD screen of your Lenovo ThinkPad T480, follow this guide. The LCD screen or liquid crystal display is a type of flat-panel display. It uses liquid crystal film between glass plates that when voltage is applied its optical properties change and images are displayed or hidden.
If damage or failure occurs you may notice missing pixels, the color could be off, or the screen could crack if it is dropped or sustains a fall.
Prior to starting this repair, be sure to disable the internal battery, turn off the device, and unplug it from the charging cable.
부품
지정된 부품이 없습니다.
Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
Using an IC extractor or black nylon spudger, unplug the connector from the socket on the motherboard.
Using the Phillips #1 screwdriver, loosen the four captive screws in the arm of the heatsink.
Using the black nylon spudger, lift the connector lock up.
Disconnect the storage cable from the system board.
Using the Phillips #1 screwdriver, remove three 4.6 mm screws from the I/O bracket.
Use the black nylon spudger to lift up the small locking flap on the power button cable's ZIF connector.
Slide the power button cable out of the ZIF connector.
Use the metal spudger to create a space between the bezel and lid and carefully undo the clips around the perimeter of the bezel.
Remove the four 3.0 mm Phillips #1 screws from the four corners of the LCD screen.
Lift it up using the spudger and flip it over gently towards you.
댓글 5개
If the internal battery is disabled why do you need to remove it?
Hi Dan, if you disconnect the internal battery from the motherboard, (Step 12), you should be fine. We just want to make sure that there is no power to the system and the step to remove the battery is included as a precaution. Thanks!
@sarahw thank you but my question was more about why do you need to physically disconnect the battery if it is already disabled in BIOS?
Hi Dan, the software disconnection is a stopgap to ensure nothing goes wrong while the device is being opened, but the only way to 100% ensure that the motherboard won't accidentally draw power and short a connection is to physically disconnect the battery.
