주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480s Hall Sensor Replacement
필요한 것
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480s Hall Sensor Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480s Hall Sensor Replacement: 2 단계, 이미지 3/3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T480s Hall Sensor Replacement: 3 단계, 이미지 2/2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: 4 단계, 이미지 1/2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: 4 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T480s Hall Sensor Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T480s Hall Sensor Replacement: 5 단계, 이미지 3/3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: 6 단계, 이미지 1/3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: 6 단계, 이미지 2/3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: 6 단계, 이미지 3/3
    • Use a spudger to disconnect the cable from the Hall sensor.
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad T480s Hall Sensor Replacement: 7 단계, 이미지 2/2
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T480s Hall Sensor Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T480s Hall Sensor Replacement: 8 단계, 이미지 3/3
    • Remove the sensor from the system.
결론
Sarah Westberg
회원 가입일: 03/11/19
24,274 평판
안내서 71개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,086개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 31
30일 전: 93
전체 시간: 2,631
