소개
Use this guide to replace the display panel on your Lenovo ThinkPad T480s laptop.
The display panel, also known as a screen, is the component that outputs visual information from a computer.
Some signs your display panel may be faulty include a blank or black screen, flickering, no backlight, or horizontal or vertical lines. A display panel replacement may be needed if it is cracked or physically damaged. Before attempting a display panel replacement, you may be able to resolve the issue using Lenovo’s troubleshooting guide.
Before replacing your display panel, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
필요한 것
Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 4개
Hello, just wondering about step 4.
The description does not match what the image is showing for the Wi-Fi card wiring. The image is showing the black wire being closest to the screw (bottom) and the grey wire being on the opposite side (top). The description describes the opposite which is correct. The correct wiring can be seen in step 3 when the lid has been opened.
Hi Kromagnon, thanks for pointing this out! I believe when I opened up the device, (which was likely used ), the Wi-Fi card cables were inadvertently switched (as shown in Step 3). I wrote my instructions based on how they were initially connected, but when reassembling I put the cables back correctly and missed the fact that the instructions were inconsistent. Step 4 is now correct. Thanks again!
Why even remove the Wifi cables? Do they actually get in the way of the replacement? I have done this before and don't think that they do.
Hi Nathan, thanks for your question. It looks like the Wi-Fi cables are connected to the display assembly, so they will need to be disconnected from the Wi-Fi card prior to removing the display.
