주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480s RAM Replacement
필요한 것
  1. Lenovo ThinkPad T480s RAM Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad T480s RAM Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s RAM Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480s RAM Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480s RAM Replacement: 2 단계, 이미지 3/3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s RAM Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T480s RAM Replacement: 3 단계, 이미지 2/2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s RAM Replacement, RAM: 4 단계, 이미지 1/3 Lenovo ThinkPad T480s RAM Replacement, RAM: 4 단계, 이미지 2/3 Lenovo ThinkPad T480s RAM Replacement, RAM: 4 단계, 이미지 3/3
    • Pull the plastic film back.
    • Push the clips outward to release the RAM stick.
    • My device doesn't have RAM so you don't see it.
    • The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
결론
Sarah Westberg
회원 가입일: 03/11/19
23,269 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,275개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 40
30일 전: 174
전체 시간: 3,809
