주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement
필요한 것
  1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 2 단계, 이미지 3/3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 3 단계, 이미지 2/2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Battery: 4 단계, 이미지 1/2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Battery: 4 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 5 단계, 이미지 3/3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: 6 단계, 이미지 1/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: 6 단계, 이미지 2/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: 6 단계, 이미지 3/3
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 7 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 8 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 9 단계, 이미지 1/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 9 단계, 이미지 2/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 9 단계, 이미지 3/3
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 10 단계, 이미지 1/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 10 단계, 이미지 2/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 10 단계, 이미지 3/3
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
  11. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: 11 단계, 이미지 1/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: 11 단계, 이미지 2/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: 11 단계, 이미지 3/3
    • Use a spudger to lift up the retaining flap on the SD card reader/audio card connector.
  12. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 12 단계, 이미지 1/2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 12 단계, 이미지 2/2
    • Use the spudger to remove the cable from the connector.
    • The cable is attached to the board with adhesive so you will need to peel the cable up.
  13. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 13 단계, 이미지 1/2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 13 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove two 3.1 mm screws from the card.
  14. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 14 단계, 이미지 1/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 14 단계, 이미지 2/3 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 14 단계, 이미지 3/3
    • Lift the SD card reader/audio card from the system by sliding it out from the socket.
    • You will need to slide the audio card ribbon cable under the coin cell battery cable to remove the SD card reader from the system.
결론
Sarah Westberg
회원 가입일: 03/11/19
23,378 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,432개 작성하였습니다
댓글 한 개
It is not necessary to do steps 8 & 9.
K CHOI - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 22
30일 전: 67
전체 시간: 1,529
