주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480s Speaker Replacement
필요한 것
  1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Speaker Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480s Speaker Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480s Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Speaker Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T480s Speaker Replacement: 3 단계, 이미지 2/2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Speaker Replacement, Battery: 4 단계, 이미지 1/2 Lenovo ThinkPad T480s Speaker Replacement, Battery: 4 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Speaker Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T480s Speaker Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T480s Speaker Replacement: 5 단계, 이미지 3/3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Speaker Replacement, Speaker: 6 단계, 이미지 1/3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: 6 단계, 이미지 2/3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: 6 단계, 이미지 3/3
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s Speaker Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad T480s Speaker Replacement: 7 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s Speaker Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T480s Speaker Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T480s Speaker Replacement: 8 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s Speaker Replacement: 9 단계, 이미지 1/3 Lenovo ThinkPad T480s Speaker Replacement: 9 단계, 이미지 2/3 Lenovo ThinkPad T480s Speaker Replacement: 9 단계, 이미지 3/3
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s Speaker Replacement: 10 단계, 이미지 1/3 Lenovo ThinkPad T480s Speaker Replacement: 10 단계, 이미지 2/3 Lenovo ThinkPad T480s Speaker Replacement: 10 단계, 이미지 3/3
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
결론
Sarah Westberg
회원 가입일: 03/11/19
23,408 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
137 회원들
안내서 17,457개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 51
전체 시간: 1,364
