주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480s Trackpad Replacement
필요한 것
  1. Lenovo ThinkPad T480s Trackpad Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad T480s Trackpad Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Trackpad Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480s Trackpad Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480s Trackpad Replacement: 2 단계, 이미지 3/3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Trackpad Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T480s Trackpad Replacement: 3 단계, 이미지 2/2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Trackpad Replacement, Battery: 4 단계, 이미지 1/2 Lenovo ThinkPad T480s Trackpad Replacement, Battery: 4 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Trackpad Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T480s Trackpad Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T480s Trackpad Replacement: 5 단계, 이미지 3/3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Trackpad Replacement, Trackpad: 6 단계, 이미지 1/3 Lenovo ThinkPad T480s Trackpad Replacement, Trackpad: 6 단계, 이미지 2/3 Lenovo ThinkPad T480s Trackpad Replacement, Trackpad: 6 단계, 이미지 3/3
    • Use the spudger to disconnect the trackpad cable from the system board.
  7. Lenovo ThinkPad T480s Trackpad Replacement: 7 단계, 이미지 1/3 Lenovo ThinkPad T480s Trackpad Replacement: 7 단계, 이미지 2/3 Lenovo ThinkPad T480s Trackpad Replacement: 7 단계, 이미지 3/3
    • Peel the cable and black sticker to reveal a hidden screw.
  8. Lenovo ThinkPad T480s Trackpad Replacement: 8 단계, 이미지 1/2 Lenovo ThinkPad T480s Trackpad Replacement: 8 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove four 2.3 mm screws.
  9. Lenovo ThinkPad T480s Trackpad Replacement: 9 단계, 이미지 1/3 Lenovo ThinkPad T480s Trackpad Replacement: 9 단계, 이미지 2/3 Lenovo ThinkPad T480s Trackpad Replacement: 9 단계, 이미지 3/3
    • Open the bottom case and remove the trackpad.
    • The ribbon cable will slide through and out of the bottom of the case.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Sarah Westberg
회원 가입일: 03/11/19
23,378 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,430개 작성하였습니다
댓글 3개
Thanks! Worked.
Drew - 답글
do you have a part number for the replacement trackpad?
Adam S - 답글
Hi Adam S, I did a search by the touchpad SKU and a general search by the make and model of the laptop but it didn't come up. Have you tried contacting Lenovo? It's possible they might have the part number even if they don't sell the part, but then you might be able to find it on the secondary market. This might be a good place to start: https://pcsupport.lenovo.com/us/en/solut.... I hope this helps!
Sarah Westberg -
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 49
30일 전: 183
전체 시간: 5,323
