주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480s Wi-Fi Card Replacement
필요한 것
  1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: 2 단계, 이미지 3/3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 1/3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 2/3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 3/3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  5. Lenovo ThinkPad T480s Wi-Fi Card Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  6. Lenovo ThinkPad T480s Wi-Fi Card Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: 6 단계, 이미지 3/3
    • Slide the Wi-Fi card out from the slot.
결론
Sarah Westberg
회원 가입일: 03/11/19
24,274 평판
안내서 71개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 28
30일 전: 128
전체 시간: 2,208
