주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T490 Base Plate Replacement
필요한 것
  1. Lenovo ThinkPad T490 Base Plate Replacement, Base Plate: 1 단계, 이미지 1/1
    • Loosen the screws from the base plate.
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 Base Plate Replacement: 2 단계, 이미지 1/1
    • Once the screws have been loosened, start to remove the base plate.
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 Base Plate Replacement: 3 단계, 이미지 1/1
    • Fully remove the base .
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
결론
ferni fuentes
회원 가입일: 02/19/24
565 평판
안내서 4개 작성하였습니다
University of Kentucky, Team 1-3, Martin Spring 2024 University of Kentucky, Team 1-3, Martin Spring 2024 회원
UKY-MARTIN-S24S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 51
전체 시간: 121
