주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T490 RAM Replacement
필요한 것
  1. Lenovo ThinkPad T490 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Remove the screws from the base plate for access to the motherboard, where the RAM is located.
  2. Lenovo ThinkPad T490 RAM Replacement: 2 단계, 이미지 1/1
    • Once the screws are off, start to remove the base plate.
  3. Lenovo ThinkPad T490 RAM Replacement: 3 단계, 이미지 1/1
    • Fully remove the base plate so you can access the RAM.
  4. Lenovo ThinkPad T490 RAM Replacement: 4 단계, 이미지 1/1
    • Locate the RAM stick (blue box on the left) and the RAM battery (blue box on the right).
  5. Lenovo ThinkPad T490 RAM Replacement: 5 단계, 이미지 1/1
    • First, for the reinstallation process, remove the RAM battery (red box on the right).
  6. Lenovo ThinkPad T490 RAM Replacement: 6 단계, 이미지 1/1
    • To remove the RAM battery, tug the black rope and disconnect the metal head from the socket.
  7. Lenovo ThinkPad T490 RAM Replacement: 7 단계, 이미지 1/1
    • For the RAM stick, first remove the black flap that is covering it.
  8. Lenovo ThinkPad T490 RAM Replacement: 8 단계, 이미지 1/1
    • Once the black flap is removed, slide the RAM stick out for further inspection. Slide it back in and place the black flap over it to restart the process.
결론
ferni fuentes
회원 가입일: 02/19/24
565 평판
안내서 4개 작성하였습니다
University of Kentucky, Team 1-3, Martin Spring 2024 University of Kentucky, Team 1-3, Martin Spring 2024 회원
UKY-MARTIN-S24S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 18
30일 전: 85
전체 시간: 210
