주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T490 Speaker Replacement
필요한 것
  1. Lenovo ThinkPad T490 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Using a Philips #1 screwdriver, fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 Speaker Replacement: 2 단계, 이미지 1/1
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the base plate in order to release the clips holding the base plate and chassis together.
  3. Lenovo ThinkPad T490 Speaker Replacement: 3 단계, 이미지 1/1
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 Speaker Replacement: 4 단계, 이미지 1/1
    • Make careful note of the location of the speaker and the battery.
    • The speaker is located in the top middle.
    • The battery is located at the bottom.
  5. Lenovo ThinkPad T490 Speaker Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad T490 Speaker Replacement: 5 단계, 이미지 2/2
    • Gently pull the pull tab in order to disconnect the battery from its socket.
  6. Lenovo ThinkPad T490 Speaker Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T490 Speaker Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T490 Speaker Replacement: 6 단계, 이미지 3/3
    • Using the Phillips #1 screwdriver, remove the three 5 mm screws from the centralized speaker.
  7. Lenovo ThinkPad T490 Speaker Replacement: 7 단계, 이미지 1/1
    • Locate the pull tab at the bottom right hand corner of the speaker.
  8. Lenovo ThinkPad T490 Speaker Replacement: 8 단계, 이미지 1/1
    • Pull the speaker pull tab in order to remove it from its socket.
  9. Lenovo ThinkPad T490 Speaker Replacement: 9 단계, 이미지 1/1
    • Remove the speaker from the case.
  10. Lenovo ThinkPad T490 Speaker Replacement: 10 단계, 이미지 1/1
    • The case should look like this after successful completion of the previous steps and safe removal of the speaker.
결론
ferni fuentes
회원 가입일: 02/19/24
565 평판
안내서 4개 작성하였습니다
University of Kentucky, Team 1-3, Martin Spring 2024 University of Kentucky, Team 1-3, Martin Spring 2024 회원
UKY-MARTIN-S24S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 33
전체 시간: 119
