주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T490s SSD Replacement
필요한 것
  1. Lenovo ThinkPad T490s SSD Replacement, Loosen the back screws: 1 단계, 이미지 1/2 Lenovo ThinkPad T490s SSD Replacement, Loosen the back screws: 1 단계, 이미지 2/2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s SSD Replacement, Release the clips: 2 단계, 이미지 1/2 Lenovo ThinkPad T490s SSD Replacement, Release the clips: 2 단계, 이미지 2/2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s SSD Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T490s SSD Replacement: 3 단계, 이미지 2/2
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: 4 단계, 이미지 1/3 Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: 4 단계, 이미지 2/3 Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: 4 단계, 이미지 3/3
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s SSD Replacement, Disconnect the battery cable: 5 단계, 이미지 1/2 Lenovo ThinkPad T490s SSD Replacement, Disconnect the battery cable: 5 단계, 이미지 2/2
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD screw: 6 단계, 이미지 1/2 Lenovo ThinkPad T490s SSD Replacement, Remove the SSD screw: 6 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the 3.7 mm-long screw holding down the SSD.
  7. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: 7 단계, 이미지 1/3 Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: 7 단계, 이미지 2/3 Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: 7 단계, 이미지 3/3
    • Pull the SSD out and away from its socket.
    • If this motion requires excessive force, walk the SSD side to side as you pull.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
Clay Eickemeyer
회원 가입일: 09/19/22
70,408 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 53
30일 전: 213
전체 시간: 4,238
