주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad T495 Battery Replacement
필요한 것
  1. Lenovo ThinkPad T495 Battery Replacement, Baseplate: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the four screws securing the battery.
    • On both sides of the plug, use your fingernails to "walk" out the battery cable connector until it releases.
  4. Lenovo ThinkPad T495 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery by lifting it up and out with your fingers
    • The battery should lift out with no resistance. If you feel any resistance, double check that the screws are removed, and that the connector is released from the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Christian Taylor
회원 가입일: 03/28/22
706 평판
안내서 6개를 작성함
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G6
3 회원들
안내서 8개를 작성함
1가이드 댓글
Can you tell me where the screen led power would be
levi martin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 40
지난 30일: 186
전체 시간: 8,873
