주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T495 Battery Replacement
필요한 것
  1. Lenovo ThinkPad T495 Battery Replacement, Baseplate: 1 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Battery Replacement: 2 단계, 이미지 1/1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four screws securing the battery.
    • On both sides of the plug, use your fingernails to "walk" out the battery cable connector until it releases.
  4. Lenovo ThinkPad T495 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery by lifting it up and out with your fingers
    • The battery should lift out with no resistance. If you feel any resistance, double check that the screws are removed, and that the connector is released from the motherboard.
결론
Christian Taylor
회원 가입일: 03/28/22
523 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G6
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 50
30일 전: 197
전체 시간: 4,436
