소개
If your laptop won't connect to Wi-Fi, the issue could be because of a damaged or broken Wi-Fi card. This guide will cover the replacement of the Wi-Fi card in the Lenovo Thinkpad T495.
필요한 것
Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
거의 끝나갑니다!
결론
