주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T495 Wi-Fi Card Replacement
필요한 것
  1. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Baseplate: 1 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 1/3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 2/3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
    • Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
  4. Lenovo ThinkPad T495 Wi-Fi Card Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad T495 Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • Grip the Wi-Fi card between your fingers and pull it in the direction of the card, at a slight angle, until it releases from its port.
결론
Christian Taylor
회원 가입일: 03/28/22
523 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G6
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 35
전체 시간: 870
