주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T495s Battery Replacement
필요한 것
  1. Lenovo ThinkPad T495s Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Do not begin until the laptop is unplugged and completely powered off.
    • Flip the laptop over to reveal the back panel of the laptop.
  2. Lenovo ThinkPad T495s Battery Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T495s Battery Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T495s Battery Replacement: 2 단계, 이미지 3/3
    • Loosen the five 4.0 mm captive screws with a Phillips #1 screwdriver.
    • The screws will stay attached to the back cover as you lift it off.
  3. Lenovo ThinkPad T495s Battery Replacement, Battery: 3 단계, 이미지 1/3 Lenovo ThinkPad T495s Battery Replacement, Battery: 3 단계, 이미지 2/3 Lenovo ThinkPad T495s Battery Replacement, Battery: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to unplug the battery connection from the motherboard.
  4. Lenovo ThinkPad T495s Battery Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T495s Battery Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T495s Battery Replacement: 4 단계, 이미지 3/3
    • Remove the five 4.5 mm screws with a Phillips #1 screwdriver.
    • There are plastic tabs at the bottom of the battery, so pull it slightly forward with your hands, toward the motherboard, before lifting straight up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ijhanne Holder
회원 가입일: 03/28/22
431 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-7, Petersen Spring 2022 UMass Dartmouth, Team 1-7, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G7
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 39
30일 전: 109
전체 시간: 2,193
