주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T495s Trackpad Replacement
필요한 것
  1. Lenovo ThinkPad T495s Trackpad Replacement, Back Panel: 1 단계, 이미지 1/1
    • Do not begin until the laptop is unplugged and completely powered off.
    • Flip the laptop over to reveal the back panel of the laptop.
  2. Lenovo ThinkPad T495s Trackpad Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T495s Trackpad Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T495s Trackpad Replacement: 2 단계, 이미지 3/3
    • Loosen the five 4.0 mm captive screws with a Phillips #1 screwdriver.
    • The screws will stay attached to the back cover as you lift it off.
  3. Lenovo ThinkPad T495s Trackpad Replacement, Battery: 3 단계, 이미지 1/3 Lenovo ThinkPad T495s Trackpad Replacement, Battery: 3 단계, 이미지 2/3 Lenovo ThinkPad T495s Trackpad Replacement, Battery: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to unplug the battery connection from the motherboard.
  4. Lenovo ThinkPad T495s Trackpad Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T495s Trackpad Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T495s Trackpad Replacement: 4 단계, 이미지 3/3
    • Remove the five 4.5 mm screws with a Phillips #1 screwdriver.
    • There are plastic tabs at the bottom of the battery, so pull it slightly forward with your hands, toward the motherboard, before lifting straight up.
  5. Lenovo ThinkPad T495s Trackpad Replacement, Trackpad: 5 단계, 이미지 1/3 Lenovo ThinkPad T495s Trackpad Replacement, Trackpad: 5 단계, 이미지 2/3 Lenovo ThinkPad T495s Trackpad Replacement, Trackpad: 5 단계, 이미지 3/3
    • Use the iFixit Opening Tool to flip up the small locking flap on the trackpad's one ZIF ribbon cable connection. The ribbon cable should easily release from its socket.
    • ZIF stands for Zero Insertion Force; if you're experiencing any resistance whatsoever during disconnection, double-check that the locking flaps are flipped up.
  6. Lenovo ThinkPad T495s Trackpad Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T495s Trackpad Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T495s Trackpad Replacement: 6 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the four 2.2 mm screws from the trackpad.
  7. Lenovo ThinkPad T495s Trackpad Replacement: 7 단계, 이미지 1/3 Lenovo ThinkPad T495s Trackpad Replacement: 7 단계, 이미지 2/3 Lenovo ThinkPad T495s Trackpad Replacement: 7 단계, 이미지 3/3
    • With the bottom of the laptop facing you, gently lift the laptop open until the trackpad drops out.
결론
Jessica Costa
회원 가입일: 03/28/22
125 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-7, Petersen Spring 2022 UMass Dartmouth, Team 1-7, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G7
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 64
전체 시간: 1,069
