필요한 것
Remove the speaker cover.
Per rimuovere questa parte occorre svitare altre due vito da sotto, sul lato posteriore
Yes, there is another screw or two that have to be removed from the underside of the laptop before you can remove the speaker cover.
martin8777 - 답글
Remove the two 3mm screws next to the lid hinges, as well as the two 3mm screws on the lid's ribbon cable.
Per rimuovere il display occorre svitare altre due vito da sotto, sul lato posteriore
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
It was of good help, but be aware that you need to remove two screws on the back before removing the speaker cover. If not you will break the cover.
