주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T500 Speaker Replacement
필요한 것
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: 2 단계, 이미지 1/1
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: 3 단계, 이미지 1/1
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: 4 단계, 이미지 1/1
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: 5 단계, 이미지 1/1
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad T500 Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: 7 단계, 이미지 1/1
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: 9 단계, 이미지 1/2 Lenovo ThinkPad T500 Speaker Replacement: 9 단계, 이미지 2/2
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad T500 Speaker Replacement: 10 단계, 이미지 2/2
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: 11 단계, 이미지 1/3 Lenovo ThinkPad T500 Speaker Replacement: 11 단계, 이미지 2/3 Lenovo ThinkPad T500 Speaker Replacement: 11 단계, 이미지 3/3
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: 12 단계, 이미지 1/1
    • Remove the speakers.
결론
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 88개 작성하였습니다
Global Fixers Global Fixers 회원
Community
34 회원들
안내서 597개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 1,227
