주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T530 External Battery Replacement
필요한 것
  1. Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: 1 단계, 이미지 1/2 Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: 1 단계, 이미지 2/2
    • Ensure that the laptop is disconnected from the wall charger, and that the laptop is entirely powered off before following any of the steps below.
    • Flip your laptop upside down, so that the keyboard is facing down.
  2. Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: 2 단계, 이미지 1/2 Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: 2 단계, 이미지 2/2
    • Locate the latch located on the battery near the top of the laptop.
    • Using your finger, slide the latch to the right-most (Unlocked) position.
    • None of this should require an exhuberant amount of force.
  3. Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: 3 단계, 이미지 1/2 Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: 3 단계, 이미지 2/2
    • You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Albert Stoynov
회원 가입일: 09/11/23
1,255 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 132
