주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T530 Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad T530 Hard Drive Replacement, Place your laptop upside down: 1 단계, 이미지 1/2 Lenovo ThinkPad T530 Hard Drive Replacement, Place your laptop upside down: 1 단계, 이미지 2/2
    • Ensure that the laptop is disconnected from the wall charger, and that the laptop is entirely powered off before following any of the steps below.
    • Flip your laptop upside down, so that the keyboard is facing down.
  2. Lenovo ThinkPad T530 Hard Drive Replacement, Unlock Battery: 2 단계, 이미지 1/2 Lenovo ThinkPad T530 Hard Drive Replacement, Unlock Battery: 2 단계, 이미지 2/2
    • Locate the latch located on the battery near the top of the laptop.
    • Using your finger, slide the latch to the right-most (Unlocked) position.
    • None of this should require an exhuberant amount of force.
  3. Lenovo ThinkPad T530 Hard Drive Replacement, Remove the Battery: 3 단계, 이미지 1/2 Lenovo ThinkPad T530 Hard Drive Replacement, Remove the Battery: 3 단계, 이미지 2/2
    • You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
  4. Lenovo ThinkPad T530 Hard Drive Replacement, Opening Storage Drive Door: 4 단계, 이미지 1/3 Lenovo ThinkPad T530 Hard Drive Replacement, Opening Storage Drive Door: 4 단계, 이미지 2/3 Lenovo ThinkPad T530 Hard Drive Replacement, Opening Storage Drive Door: 4 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove the bottom screw to unlock the storage drive cover.
    • Lift up the storage drive cover from the lip highlighted in orange. Put it aside.
  5. Lenovo ThinkPad T530 Hard Drive Replacement, Removing Storage Drive: 5 단계, 이미지 1/2 Lenovo ThinkPad T530 Hard Drive Replacement, Removing Storage Drive: 5 단계, 이미지 2/2
    • Pull the storage drive out of the slot from the tab.
    • Pull the drive at an angle, and not directly up as this could cause damage to the sata connector.
  6. Lenovo ThinkPad T530 Hard Drive Replacement, Removing Drive Spacers: 6 단계, 이미지 1/2 Lenovo ThinkPad T530 Hard Drive Replacement, Removing Drive Spacers: 6 단계, 이미지 2/2
    • Grab the rubber spacers highlighted in red, and pull them away from the drive.
  7. Lenovo ThinkPad T530 Hard Drive Replacement, Removing the Drive from the Caddy: 7 단계, 이미지 1/2 Lenovo ThinkPad T530 Hard Drive Replacement, Removing the Drive from the Caddy: 7 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, unscrew the four screws, two on each of the left, and right side of the drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Albert Stoynov
회원 가입일: 09/11/23
1,255 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 44
전체 시간: 188
