주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T560 Battery Replacement
필요한 것
  1. Lenovo ThinkPad T560 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Battery Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 Battery Replacement, Battery: 3 단계, 이미지 1/2 Lenovo ThinkPad T560 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
  4. Lenovo ThinkPad T560 Battery Replacement: 4 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
결론
Jackson Reynolds
회원 가입일: 02/27/22
517 평판
안내서 5개 작성하였습니다
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G3
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
Is there any way to disable the battery whitelist or otherwise get the device to work with 'unauthorized' external batteries as OEM external batteries are no longer produced by Lenovo or sold by any vendor including ifixit itself? I've had some that worked for close to a year now up until yesterday, when the laptop suddenly decided they are no longer official.
David L. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 38
30일 전: 143
전체 시간: 2,969
