주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T560 SSD/Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, SSD/Hard Drive: 3 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
  4. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: 4 단계, 이미지 1/1
    • Pick up the SSD/Hard Drive and unplug it from the cable connecting the SSD/Hard Drive to the motherboard.
  5. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: 5 단계, 이미지 1/1
    • Remove SSD/Hard Drive case from the drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jackson Reynolds
회원 가입일: 02/27/22
517 평판
안내서 5개 작성하였습니다
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G3
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 51
30일 전: 192
전체 시간: 4,316
