주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T580 RAM Replacement
필요한 것
  1. Lenovo ThinkPad T580 RAM Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T580 RAM Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T580 RAM Replacement, External Battery: 1 단계, 이미지 3/3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 RAM Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T580 RAM Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T580 RAM Replacement: 2 단계, 이미지 3/3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 RAM Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T580 RAM Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T580 RAM Replacement: 3 단계, 이미지 3/3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 RAM Replacement, Bottom Case: 4 단계, 이미지 1/2 Lenovo ThinkPad T580 RAM Replacement, Bottom Case: 4 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 RAM Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T580 RAM Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T580 RAM Replacement: 5 단계, 이미지 3/3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 RAM Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T580 RAM Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T580 RAM Replacement: 6 단계, 이미지 3/3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 RAM Replacement, Internal Battery: 7 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 RAM Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T580 RAM Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T580 RAM Replacement: 8 단계, 이미지 3/3
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 RAM Replacement, RAM: 9 단계, 이미지 1/3 Lenovo ThinkPad T580 RAM Replacement, RAM: 9 단계, 이미지 2/3 Lenovo ThinkPad T580 RAM Replacement, RAM: 9 단계, 이미지 3/3
    • Pull the two tabs on either side of the RAM card outwards with your fingers.
  10. Lenovo ThinkPad T580 RAM Replacement: 10 단계, 이미지 1/3 Lenovo ThinkPad T580 RAM Replacement: 10 단계, 이미지 2/3 Lenovo ThinkPad T580 RAM Replacement: 10 단계, 이미지 3/3
    • The RAM module should pop up to rest at an angle to the motherboard.
    • Pull the Wi-Fi card out from the port by the edges of the card.
    • Try to remove and insert the card at the same angle at which it rests with respect to the motherboard.
  11. Lenovo ThinkPad T580 RAM Replacement: 11 단계, 이미지 1/2 Lenovo ThinkPad T580 RAM Replacement: 11 단계, 이미지 2/2
    • Remove the RAM module from the laptop.
    • Repeat the same process for the second RAM module if your computer included one.
결론
Austin Blakely
회원 가입일: 03/11/19
19,961 평판
안내서 53개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 26
전체 시간: 1,275
