주요 콘텐츠로 건너뛰기
Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
필요한 것
  1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): 1 단계, 이미지 2개 중 2개
    • Turn your laptop over so the backplate is facing you.
    • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
    • These screws should stay put on the backplate, and should not fall off.
  2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 2 단계, 이미지 2개 중 2개
    • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
  3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
    • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
  4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 4 단계, 이미지 1개 중 1개
    • Once the ODD has popped out, simply grab and pull out the drive bay.
결론
작성자
3다른 기여자 명과 함께
Isaac
회원 가입일: 10/30/23
205 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G1
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 211
