주요 콘텐츠로 건너뛰기
Lenovo ThinkPad W541 Touchpad Replacement
필요한 것
  1. Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: 1 단계, 이미지 1/2 Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: 1 단계, 이미지 2/2
    • Slide the clips to the left and right sides, remove the battery upwards.
    • Loosen two Phillips #00 screws and open the cover plate.
    • Remove four 9.0 mm Phillips #00 case screws.
    • Remove three 9.0 mm Phillips #00 screws circled with red in the second picture.
  2. Lenovo ThinkPad W541 Touchpad Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad W541 Touchpad Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad W541 Touchpad Replacement: 2 단계, 이미지 3/3
    • Use the pry bar to push the keypad below the slot shown in the first picture and push it upward.
    • Loosen six Phillips #000 screws circled with red in the second picture, lift up the keyboard.
  3. Lenovo ThinkPad W541 Touchpad Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad W541 Touchpad Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad W541 Touchpad Replacement: 3 단계, 이미지 3/3
    • Open the black clips according to the direction marked in the first picture and remove the cable.
    • Use a pry bar to pry open the black protective casing upwards.
    • Follow the direction shown in the third picture, open the black clips upwards and remove the cable.
  4. Lenovo ThinkPad W541 Touchpad Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad W541 Touchpad Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad W541 Touchpad Replacement: 4 단계, 이미지 3/3
    • Remove the four 2.0 mm Phillips #000 screws circled with red in the first picture.
    • Carefully remove the metal tape shown in the second picture and paste it back on after replacing the new touchpad.
    • As shown in the third picture, remove the trackpad that needs to be replaced.
  5. Lenovo ThinkPad W541 Touchpad Replacement: 5 단계, 이미지 1/1
    • You can replace your touchpad with a new one. To install your computer just follow this guide in reverse.
결론
Panaien Liu
회원 가입일: 01/31/23
121 평판
안내서 1개 작성함
York University, Team P-5, Allen Winter 2023 York University, Team P-5, Allen Winter 2023 회원
YORK-ALLEN-W23SPG5
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 395
