소개
If the laptop no longer starts and the screen remains black, the cause can be a flat Bios battery. This is simply replaced, after which the device works again without problems.
필요한 것
Make sure the laptop is off and remove the battery.
Loosen all screws (these remain in the case bottom) with a PH 00 screwdriver.
Open the clips around the case with an iFixit opening tool.
To remove the case bottom, you have to lift it slightly and push it backwards.
Be careful not to damage the case!
Carefully remove the foil
Disconnect the plug of the battery.
Remove the battery from the circuit board. This is glued to the circuit board with a spacer.
Find a replacement battery based on the type designation (in my case a 08K8050 - CR 2032 3V) and insert it.
Work through the steps in reverse order to reassemble your device.
다음 번역가들에게 특별히 감사 드립니다:
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
