주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Fan: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 7 단계, 이미지 1개 중 1개
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the fan by lifting it directly up.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Disconnect all 10 of the ribbon cables attached to the motherboard.
  10. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 10 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the wire connecting the motherboard to the speaker.
  11. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 11 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding the metal covering over the power jack prongs.
  12. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 12 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding down the Micro-SD card tray.
  13. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 13 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 13 단계, 이미지 2개 중 2개
    • Un-tape the orange and blue wires from the motherboard.
  14. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the black and grey wires from the cable comb on the motherboard.
  15. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 15 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 15 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to unscrew the 3.7mm screw holding down the wifi card.
    • Remove the wifi card.
  16. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 16 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 16 단계, 이미지 2개 중 2개
    • Carefully remove the motherboard by lifting it and pulling towards the left.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eevee Murdock
회원 가입일: 01/23/20
1,134 평판
안내서 6개를 작성함
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020 회원
CPSU-WHITE-W20S18G4
4 회원들
안내서 9개를 작성함
2가이드 댓글
All going as described, until the final step trying to pull the motherboard out, and there is something still holding it in place. With a bit of a wiggle and pull, there is something about near the screw hole that was holding the wifi card down preventing the card from lifting there. Any clues?
Tim Ellison - 답글
Answering my own question: Removing the motherboard requires that you first pop the SIM card / MicroSD card holder out of the socket, otherwise it won’t lift out. Submitted an update to the guide to save others falling into the same trap.
Tim Ellison -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 66
전체 시간: 4,664
