주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Touchpad: 6 단계, 이미지 1개 중 1개
    • Remove the black ribbon cable connected to the touchpad.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 7 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the four 1.9 mm screws holding in the touchpad.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the touchpad by opening the computer and letting it drop onto your hand.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Eevee Murdock
회원 가입일: 01/23/20
1,134 평판
안내서 6개를 작성함
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020 회원
CPSU-WHITE-W20S18G4
4 회원들
안내서 9개를 작성함
2가이드 댓글
Even the weirder of their models is still amazingly engineered, this was so easy to do and finding parts - not only of the same model but compatible newer parts - was an absolute breeze! Was able to upgrade my laptop during my work lunchtime, and still have time to actually eat lunch!
Casey - 답글
Just to confirm - Thinkpad X1 Carbon Generation 3 touchpads are compatible with this model, and make for an amazing upgrade.
Casey - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 2,120
