주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Back Cover: 1 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Battery: 3 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Battery: 3 단계, 이미지 2/2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: 4 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: 5 단계, 이미지 1/1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, USB Audio Port Board: 6 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the 2.9 mm screw that is holding down the USB audio port board.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: 7 단계, 이미지 2/2
    • Undo the clasp under the USB audio port board.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: 8 단계, 이미지 1/1
    • Remove the USB audio port board from the laptop.
결론
Eevee Murdock
회원 가입일: 01/23/20
1,086 평판
안내서 6개 작성하였습니다
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020 회원
CPSU-WHITE-W20S18G4
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 990
