주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal
필요한 것
  1. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal, Back Cover: 1 단계, 이미지 1/1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal: 2 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal: 3 단계, 이미지 1/1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
결론
If you follow these steps the back of the laptop will be exposed so you can work on other components of the laptop.
To put it back together follow these steps in reverse
Diego Garcia reyes
회원 가입일: 09/01/21
493 평판
안내서 5개 작성하였습니다
Gateway, Team 1-3, Saknee Fall 2021 Gateway, Team 1-3, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G3
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 32
30일 전: 162
전체 시간: 2,907
