주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 5th Gen Battery Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 5th Gen Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Battery Replacement: 2 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Battery Replacement: 3 단계, 이미지 1/1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Battery Replacement, Battery: 4 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 5th Gen Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Battery Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad X1 Carbon 5th Gen Battery Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad X1 Carbon 5th Gen Battery Replacement: 5 단계, 이미지 3/3
    • Remove the battery using your hand or a prying tool.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Royve Mateos
회원 가입일: 09/01/21
415 평판
안내서 1개 작성함
Gateway, Team 1-3, Saknee Fall 2021 Gateway, Team 1-3, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G3
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 48
30일 전: 245
전체 시간: 6,300
