주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 2 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 3 단계, 이미지 1/1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Battery: 4 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 5 단계, 이미지 3/3
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, CMOS Battery: 6 단계, 이미지 1/1
    • Once the battery is removed the CMOS battery will be exposed.
  7. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 7 단계, 이미지 2/2
    • Disconnect the CMOS cable from the socket on the motherboard.
  8. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: 8 단계, 이미지 1/1
    • Remove the CMOS battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Diego Garcia reyes
회원 가입일: 09/01/21
493 평판
안내서 5개 작성하였습니다
Gateway, Team 1-3, Saknee Fall 2021 Gateway, Team 1-3, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G3
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 166
30일 전: 810
전체 시간: 19,018
