주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: 2 단계, 이미지 1개 중 1개
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: 4 단계, 이미지 3개 중 3개
    • Use the Phillips #1 screwdriver to remove all five 1 mm screws holding the fan and heat sink down.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: 5 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: 5 단계, 이미지 2개 중 2개
    • Pick up the fan and heat sink and carefully and remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Diego Garcia reyes
회원 가입일: 09/01/21
502 평판
안내서 5개를 작성함
Gateway, Team 1-3, Saknee Fall 2021 Gateway, Team 1-3, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G3
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 51
전체 시간: 2,969
