주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement, Back Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement: 2 단계, 이미지 2/2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement, Battery: 3 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement, Battery: 3 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement: 4 단계, 이미지 1/1
    • Take out the battery by lifting it from the top edge of the laptop, and then pulling away from the motherboard.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement, Display: 5 단계, 이미지 1/3 Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement, Display: 5 단계, 이미지 2/3 Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement, Display: 5 단계, 이미지 3/3
    • Disconnect the two display cables from the motherboard by lifting the press fit connectors off the board with a spudger.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement: 6 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, remove the six 5 mm screws connecting the display hinges to the device.
  7. Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement: 7 단계, 이미지 1/3 Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement: 7 단계, 이미지 2/3 Lenovo ThinkPad X1 Carbon 6th Gen Display Replacement: 7 단계, 이미지 3/3
    • Open the device display to open the hinges.
    • Pull the raised half towards yourself to remove the key board.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Dylan McDowell
회원 가입일: 09/16/20
433 평판
안내서 3개 작성하였습니다
댓글 2개
This only explains how to remove the complete lid assembly. What about replacing the screen itself??
Chris Herring - 답글
Yes, I agree this guide is not complete. There are 2 types of bezels and they stick onto the screen rather than being fastened or clipped. In order to actually replace the LCD part listed here the bezel will need to be peeled off and it needs to be replaced as well since the adhesive isn't designed to be reused. From what I recall (and this is to be taken with a grain of salt as I last did this exact replacement 2 years ago), once the lid assembly is removed from the hinges and bezel peeled off, the LCD just pops out.
Philip Lee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 81
30일 전: 319
전체 시간: 10,856
