주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement, Back Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: 2 단계, 이미지 2/2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement, Fan: 3 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement, Fan: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to loosen the four screws that secure the fan to the motherboard.
    • The screws do not completely come off from the fan mount. Loosen until the screws are completely loose.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Nylon Tipped Tweezers
    구매
    • Use nylon tipped tweezers, or your fingers, to gently pull the fan's power cable towards the SSD, disconnecting it from the pins.
    • Be sure to pull on all of the cables at the same time.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening pick to lift the fan mount.
    • Use your fingers to gently pull the fan diagonally away from where it is connected.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: 6 단계, 이미지 1/1
    • Turn the fan over to expose the interior.
    • If necessary, clean out the fan or wipe away and replace the thermal paste.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Michael Megna
회원 가입일: 01/23/20
1,265 평판
안내서 7개 작성하였습니다
Cal Poly, Team S19-G4, White Winter 2020 Cal Poly, Team S19-G4, White Winter 2020 회원
CPSU-WHITE-W20S19G4
3 회원들
안내서 22개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 68
30일 전: 269
전체 시간: 7,982
