주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, Back Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 2 단계, 이미지 2/2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, SSD: 3 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, SSD: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the single screw that secures the SSD to the motherboard.
  4. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 4 단계, 이미지 1/1
    • Carefully remove the SSD by lifting it and pulling it out of the pins towards the battery of the laptop.
  5. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: 5 단계, 이미지 2/2
    • Carefully peel the thermal pad off of the back of the SSD.
    • If the thermal pad is in good shape, you can reuse it by applying it to the replacement SSD.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Michael Megna
회원 가입일: 01/23/20
1,265 평판
안내서 7개 작성하였습니다
Cal Poly, Team S19-G4, White Winter 2020 Cal Poly, Team S19-G4, White Winter 2020 회원
CPSU-WHITE-W20S19G4
3 회원들
안내서 22개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 92
30일 전: 447
전체 시간: 19,357
