소개
In this guide, you will learn how to replace the touchpad of a Lenovo ThinkPad X1 Carbon 6th Gen. This may be necessary if your touchpad is no longer working properly. If you are having issues with your touchpad, see our troubleshooting guide. Before replacing the touchpad, try updating or reinstalling the drivers first. Be sure to power off your device and disconnect it from any power source before beginning.
필요한 것
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
Use the Phillips #0 screwdriver to remove the 2mm screw that secures the cover of the fingerprint scanner.
다른 한 분이 해당 안내서를 완성하였습니다.
