주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Back cover removal: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Back cover removal: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Remove the back cover: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Remove the back cover: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Remove the back cover: 3 단계, 이미지 3개 중 3개
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon Answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
24,955 평판
안내서 105개를 작성함
1가이드 댓글
Hola! gracias por el manual!
¿Dónde puedo conseguir la pieza de plástico (o pua) para soltar los clicks que fijan la tapa a presión?
JoseMa - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 66
전체 시간: 5,133
