주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Back cover removal: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Back cover removal: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Remove the back cover: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Remove the back cover: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Remove the back cover: 3 단계, 이미지 3개 중 3개
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Unfasten the battery: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Unfasten the battery: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
  5. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Remove the battery: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Remove the battery: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Remove the battery: 5 단계, 이미지 3개 중 3개
    • Lift the battery straight out of its recess and remove it.
  6. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    • Remove the connectors with bar latches by lifting up on the small bar behind the port and pulling the circuit ribbon away from the port.
  7. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the snap connectors by lifting straight up until the connection pops out.
    • Use an opening tool to pry them off if a finger cannot get underneath the connection.
  8. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the latch connections by lifting the latch up, releasing the circuit ribbon.
    • Use an opening tool to get underneath the latch if a finger cannot.
  9. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the insert connections by pulling the connector away from the port.
  10. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the seven 4 mm Phillips #0 screws that hold the motherboard in place
    • Remove the 3 mm Phillips #0 screw located near the fan.
  11. Lenovo ThinkPad X1 Carbon 7th Gen Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the motherboard with the fan still connected straight up and out of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Hayden Jeanor
회원 가입일: 01/23/20
523 평판
안내서 3개를 작성함
Cal Poly, Team S19-G2, White Winter 2020 Cal Poly, Team S19-G2, White Winter 2020 회원
CPSU-WHITE-W20S19G2
4 회원들
안내서 21개를 작성함
1가이드 댓글
Do you have this motherboard? I bought this laptop a year ago and It does not power on. If you have any idea on it mail me at biplavraut@gmail.com or any link would be helpful. Thank you in advance.
biplavrautfb - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 51
지난 30일: 145
전체 시간: 6,636
