주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Back cover removal: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Back cover removal: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the back cover: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the back cover: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the back cover: 3 단계, 이미지 3개 중 3개
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Unfasten the battery: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Unfasten the battery: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
  5. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the battery: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the battery: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the battery: 5 단계, 이미지 3개 중 3개
    • Lift the battery straight out of its recess and remove it.
  6. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Track Pad: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Track Pad: 6 단계, 이미지 2개 중 2개
    • Peel back the black adhesive tape covering the ribbon cable connecting the trackpad and fingerprint scanner to the motherboard.
    • Remove the four 2mm screws securing the trackpad with a Phillips #000 screwdriver.
  7. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement: 7 단계, 이미지 1개 중 1개
    • Use an opening tool to lift up the connecter ribbon lock and pull the connector ribbon out allowing the track pad to be removed.
  8. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement: 8 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement: 8 단계, 이미지 2개 중 2개
    • Flip the laptop over and open it.
    • Use an opening pick to carefully lift the trackpad out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Oliver Parker
회원 가입일: 01/23/20
151 평판
안내서 1개를 작성함
Cal Poly, Team S19-G2, White Winter 2020 Cal Poly, Team S19-G2, White Winter 2020 회원
CPSU-WHITE-W20S19G2
4 회원들
안내서 21개를 작성함
1가이드 댓글
Where did you get the new trackpad?
janamansour - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 35
지난 30일: 101
전체 시간: 5,692
